08 kia sorento
Hello I have a 08 kia Sorrento replaced alternator and battery and that 150 fuse that goes on the positive cable and it sparks really bad I'm thinking the ground wire is touching something but I don't know where the ground wire is ...I need help can anybody show me a picture of where its located pleaseeeee?
Follow the Black(negative) cable, from the battery to the end, which most likely will be the frame. More likely you have an issue with the Positive cable. Did you install the alt and batt yourself?
Does the fuse you are putting in pop or just spark?
08 kia sorento
It sparks really bad and someone put the alternator on and when I connected the battery it sparked really bad..it started so I let it run n the p..started dimming out then all the lights came on n the dash board now it won't start..I'm thinking the ground wire is damaged
113854
Not sure y that's happening
someone else did
