sedona 2.9 LS
Hi all recently been getting a grinding noise from the front end especially when slowing down from speed and turning left handlers I have stripped the breaks down they're. Fine any ideas wheel bearing or something else thanks in advance
2004 kia sedona
I'm thinking wheel bearings. Raise up the front of the vehicle, grab the top and the bottom of the the tire at the same time, push in on the top while pulling out on the bottom, then push on the bottom and pull on the top. If you can get the tire to move when doing this you probably have a wheel bearing going bad.
Kia Sedona 2.9CRDi LX Auto 2003
I took my car in with a similar problem. Wheel bearing needed doing but also the hub assembly that the wheel bearing fits on was badly worn.
Must be a known problem as the dealer had one in stock for £78 + vat.
