1 - 20 of 34 Posts
2000 Kia sportage 4x4 4dr
project "KamoKia"
i like my 2000 4x4 5 spd so much i went and got another one...well this one is a 95 4x4 auto. has cold ac and drives good and stole it for $600. will post some pics later
Discussion Starter · #2 ·
here it is... and i have already started work on it. getting ready to rhinoline the interior.
SOHC or DOHC?
UPYOURKIA
its a DOHC...heck yeah....but has 239k miles on it, but runs great.
Was wondering if Kia made a SOHC 4x4 Auto in 95. Gearing in the 5 speed trans is different (lower 1st and 2nd). Thought they may have done the same in the auto.
Do you have a folded fin trans oil cooler or is it the coil pipe under the front splash pan?
Anyway, should be a great project.
UPYOURKIA
Discussion Starter · #8 ·
its the coil pipe.....will be upgraded!
just converted the abs system to std brakes on my 95. swapping out rear axles to go from 26 spline to 28 spline and bigger rear brakes.new axle came out of my parts 2002 sportage
Discussion Starter · #9 ·
will a 2002 2wd rotor fit on a 1995 4x4? it has new rotors and i would like to swap them. also do i have to take the 4x4 hub off to remove the rotor?
Should work same part # as per rock auto
you don't have to remove the hub just the 2 phillips head screws ( pada)and throw them away their just there to hold the the rotor during assembly.
Chief
Discussion Starter · #12 ·
thank you very much. i now have a 02 rear axle with the 28 spline axle and bigger brakes.
Discussion Starter · #15 ·
damn drunk drivers...i got hit today and the a-hole did not stop. white ford flatbed early 80's model. my lil kia got messed up. me and alex was in it when it happened.
1999 Sportage A/T 4WD
The Lord is remembering you to not give too much importance to any object; they are just stuff, they are His gifts for helping us in our lives, they are not given us for our pleasure.
Discussion Starter · #18 ·
yeah we are...kia is getting fixed to...just this time no holds barred.
Discussion Starter · #20 ·
not quite...lol its getting frame mods...lowering strut towers,and figuring out how to lower diff crossmember and a-arms. and rasing the body mounts and whatever eles i can come up with. going to try to get 4-5" of lift and not run into cv angle problems and clear a tire between 31-33"...even if i got trim the crap out of it.
1 - 20 of 34 Posts
