1 - 8 of 8 Posts
Sorento 2014 EX
What is a good tow cable in case kia suv get stuck?
Sent from my SM-G965W using Tapatalk
2017 Kia Sorento (run about)
For vehicles, recommend Heavy Duty Recovery strap - 30 feet long. Always go HD in case the Tow Vehicle needs to give your stuck vehicle a little "yank". And best of all, HD rating is only a few dollars more - compared to lower lbs recovery cable.
A good HD recovery Tow cable from Amazon might work for you. For example: [ame]https://www.amazon.ca/Strap-Reinforced-Vehicle-Recovery-Capacity/dp/B01CUXRJXA/ref=sr_1_2_sspa?ie=UTF8&qid=1549488673&sr=8-2-spons&keywords=30%27+recovery+strap&psc=1[/ame]
Hope this helps.
Sorento 2014 EX
A good HD recovery Tow cable from Amazon might work for you. For example: https://www.amazon.ca/Strap-Reinforced-Vehicle-Recovery-Capacity/dp/B01CUXRJXA/ref=sr_1_2_sspa?ie=UTF8&qid=1549488673&sr=8-2-spons&keywords=30'+recovery+strap&psc=1
Hope this helps.
I like it. Is this rope strong enough to tow Sorento out of deep snow?
Sorento is "Base Curb Weight (lbs.): 4,101" lbs (2 tons). This tow cable is rated for 20,000 lbs (10 tons).
My guess is this cable is strong enough. Even for a few gentle yanks.
2019 Sorento SX AWD
Sorento 2014 EX
Discussion Starter #8
Should I buy tow hook that screw into front of the car? Is it safe to leave the hook on the car permanently?
1 - 8 of 8 Posts
