I'm seeing a common theme here and it seems that logic is escaping everyone... to have fun in a car (full throttle starts, etc.) that requires the motor to work hard and for it to work hard, it needs energy. That energy is fuel, be it petrol (gasoline) or diesel.
Now think of it this way, you're off running at a fast pace and you get tired quickly. That's because you have used up most of your energy storage. However, this time you jog at a steady pace and find that you can go much further as you're using less energy.
Also for the bike riders out there..
Laying the power down up a hill, grinding away uses up a lot of energy and you find that you'll need to drop down gears to make it to the top.
Now do the same hill except you're spinning the cranks at a constant, easy rhythm. You will feel far more energetic at the top compared to grinding up due to the smaller energy consumption it took!
THE SAME APPLIES TO VEHICLES
no matter how efficient they claim the car to be, in order to have fun, ANY CAR will use up whatever its energy storage is very quickly. Plant the throttle in a 6 litre V12, use half a tank of fuel (bit of an over exaggeration but still). Plant the throttle in the little 1.6 litre GDi, use up a lot of fuel doing so.
So can everyone get this into their head: planting the throttle at any given moment, taking corners way too quickly and hard braking uses up more fuel than granny driving which can be seen as smooth and not very jerky.
Yes it may be boring but you get better efficiency, which is how these eco cars are marketed as.
Want spirited driving? Expect crap consumption. Any car. Even the Smart car.
--End Rant--
--End Rant--
