Good day,
Kia Rio as is - h???????????? Kia - ??????????? ??????? ?????????
75 000 miles
it all started with the fact that there was a crack turn the key, lit start, decided that the battery died, good varta and it's only a year, but has previously been a strong frost and 1n friend said if not charge the battery before the frost
it burst, and so on., bought a new set, the next day, skated a frosty morning the same situation, the car will not start banging is when the key is turned, resulting in akuum pordke decided to sin on generator, generator shot brought spices, specially when I checked on the stand say exactly works and gives 100% of the charge, said the case in a relay or a computer that does not give the command to charge, + off not check the battery is not in the instrument, an old friend gave Accum, 2nd week of normal flight. Yes to remove genes to check belt tension, everything is OK.
pls halp in our forum there is no any good ideay ?
from russia with respect !)
75 000 miles
