1 - 1 of 1 Posts
Purchased a Sedona 04, Only3000 miles and had to replace the gas tank (in warr). The problem occured when I would fill the tank, the gas would shoot out of the gas hole while the nozzle was still in, at a little over half of tank according to the gas gauge. The check valve was stuck open in the tank. Also I had an oil leak coming from where the motor meets the transmission. Had the dealer tighten the bolts up, I will observe to see if that took care of the leak. Now inside we have a noise coming from the push buttons for the garage door opener, it is preety annoying. Really happy with the space of the van.
From 1 to 10 mechanically 5
1 - 1 of 1 Posts
