GREAT DEAL....
For limited period only, Fully synthetic servicing package (5W-40) for $68 ONLY...
PACKAGE INCLUDES:
1. Engine Oil change 4 Litres (SYN ACE SAE 5W-40)
2. Oil Filter Change
3. Clutch Fluid Check
4. Power Steering Fluid Check
5. Brake Fluid Check
6. Radiator Water Check
7. Coolant Check
8. Windscreen Washer Check
9. Air Filter Check
10. Battery Water and Terminal Check
11. Fan Belt Check
12. Air Conditioner Belt Check
13. Lights Check
14. Tyre Pressure Check
15. Transmission Fluid Check
16. Undercarriage Check
PLUS
AIR CON GAS TOP UP TOTALLY FREE.... worth $5
PLUS
FREE 5 X CAR WASH worth $30
ALL THE ABOVE FOR ONLY THE PRICE OF $68....
Please call 98508561 or 81177338 to purchase the servicing package while it lasts....
Clutch Fluid Check
do you mean trasmission fluid check???
and 68 bucks for checking a few things and a oil change???
GOt a oil change just today for my jeep cherokee with 5.5 quarts for 22.00. 68 a bit steep isnt it?? heres my list of what they did for 20.00 bucks.
5.5 quarts of 10w30
replaced oil filter
checked brake fluid, power steering fluid, trasmission fluid, radiator level and fluid check, topped off washer fluid, check anifreeze protection temp, inspect air filter, inspect belts and hoses, inspect and check tire preasure, and lube all fittings, checked horn, all lights,wiper blade check, check motor mounts, cv joints,shocks struts, muffler converter... all for 22.00
68 is a lot for an oil change and checking a few componets.
and 5w 40 is not recommended. not bad but not what the manufacturer says to use.
either 5w30 or 10w30 is recommended from manufacturer.
