Hi,
2002 Kia Rio 5sp manual here with a new problem - senms like the engine starves for fuel at around 2500+3000 RPM (no tach so I'll not exactly sure). When I hold the throttle at the point where power falls flat, the engine power cycles/surges, if that makes sense.
Any ideas or things to look at would be most appreciated.
Thanks!!
Thanks!!
Hmm, could be fuel filter, MAF, any codes?
Also you can pull a tached cluster from a junkyard or on eBay. just swap the speed meter so you can retain your mileage. Should be plug and play.
Thanks. No codes yesterday, but I have a MIL now that I'll check after work. I have replaced the MAF but maybe it's a good time to do the full filter, not sure when that was last done.
Thanks!
Discussion Starter #6
Update for those interested - turned it to be a faulty crankshaft position sensor.
Thanks all!
