2001 KIA Sportage
Ok my Sporty just started the intermittant starting problem. I am just gonna replace the relays right off the bat. The main I understand is in the fuse block and I should not have a problem with it. But the fuel pump relay????? I have checked KGIS and can't find where it is. I see on some posts they say about being behind the dash but which one will it be??? Thanks
The fuel pump relay is right next the main relay, same part # and they are interchangeable. If you find a bad one suggest replacing it with one from rock/auto or kia oem part. Members have reported a problem with some after market relays.
chief
