The fule pump is located under the back seat, there is a wire hook up to it and 2 fuel lines loose it and it will go out. remember first to disconect the battery terminals. Fuel tank pic will show you
the fuel filter is located at engine compartment at Intake back is a steel cylinder with pipes going in at one side and other to other side. Use a long nose plier to unhook the piping # 1 & # 2. Then unscrew # 3 and open strap. Same Backwards.
