i was woundering where my fuel filter was located, and if there was any performance things i could add on to my car?
thanks
Make sure you unplug the fuel pump and let the car run out of gas so there will be no pressure when you remove the gas lines. The plug for the fuel pump is under the back seat cushion. Lift the cushion and take the 4 phillips screws out and you will see 3 plugs there, the larger one on the right side is for the fuel pump. I just changed mine yesterday, my 2003 Rio was stalling at stop signs and bucking while at highway speeds.
