I have a Sedona 2.9 Auto Diesel, 2000, and the fuel door release switch on the drivers side burned-out (ie. it melted for some strange reason). I have just replaced it and it still does not work. I thought the fuse would have blown and as I do not know which is the correct one I have checked each one of the them located in the drivers side foot-well and they are all fine. Anyone any ideas please?
2009 KIA Sedona LX
its is in the rear cargo area fuse panel, should be a 15 amp fuse...
I have checked both sides in the rear cargo area and there is no fuse panel. There is a fuse panel located in the front drivers side (as mentioned before) but there is no reference within the labelling on the back of the cover/ door referencing the fuel cover. I have found the cable to manually open the fuel cover, which is also where the car jack is stowed along with the rear washer bottle in the rear left hand-side. Quite bazaar...
2009 KIA Sedona LX
the fuse panel is behind the black bag that holds the tire iron and jack... Thats where it is on my Canadian model... maybe different for you.
