That is a fuel tank pressure sensor voltage low DTC,
it could be the FTPS, or it could be an issue w/ wiring:
Recommend, using a digital multimeter, to check the voltage at the FTPS connector / follow the diagnostic steps for the code:
Link to online manual *thanks DavesSpectra:
https://drive.google.com/folderview?id=0B-YuNuTyh57XUXZKRnlLMV9sMTA&usp=sharing
( File: Group00.pdf is table of contents: )
Diagnostic Tree for DTC code is in file:
Group21-3.PDF, "Emission Control System 21-59"
FTPS inspection / removal procedure in file:
Group22-2.PDF,
Regards,
GottaCruise
