1 - 11 of 11 Posts
Anybody familiar with this noise. Just started about a month ago. Has been making a clicking type of noise also while downshifting coming to stops.
From Where? The Brakes,
Shifter, Steer Wheel, Drivetrain, Engine, Tranny, CV joints, etc. ??? how many miles on the SUV?
2012 Sorento 2.4 GDI, 2016 Forte5 SX
I was also getting a mild clunk on the downshift into first when coming to a stop. Turned out to be the driver side CV axle. There was about 1/8 inch of radial movement inside the CV joint hub near the transaxle housing. Installed a new NAPA CV axle at about 110000 miles and it drives like new again.
2013 Sorento Ex V6
I have the same noise on my sorento. Clicks while slowing down, about 20mph or below. Occasional click when starting off. Sounds like left of center towards the front wheel??? IF this is the CV joint/axle, is this considered a warranty driveline event. 23K miles.
Sorento 2012
If it is under 6 years or 60,000 miles, which ever occurred first, it may be covered under warranty in the US if you are the original owner and purchased the car new. The six years is from the date of purchase, not the year of the car.
2013 Sorento Ex V6
Silver 2012 Kia Sorento FWD Base with 2.4L
You try checking the retaining clips on the brake pads? Mine made noise and I put grease on both ends or replaced them and the noise went away.
2011 Kia Sorento
I recently put anti-seize on the brake pads as well recently. And then it started making those knocking sounds at low speed.
But not 100% sure yet.
1 - 11 of 11 Posts
