2004 Sorrento Ex
So I just got this 04 Sorento EX from my mother 3 weeks ago. She always kept it under cover and did not know the drains for the sunroof were blocked. Well we got all those cleaned, the left side had what looked like chips of concrete coming out of the tip when we cleaned it out. Now my issue is that the sunroof is closed but was working up until I got it. Because the drains were clogged the water was draining down inside of the cabin and soaked just about everything from the headliner above the visors down to the carpet on both sides. The issue is that when I try to use the controls to operate the sunroof nothing happens. We checked the fuse and even changed it out to no avail. The tracks were maintained so it has nothing to do with the maintenance of the sunroof itself. Is there a relay that I can check? We cleared the drains just yesterday and had a very strong rain storm afterwards. Everything inside was dry after the rain. Any help would be great, please and thank you.
2008 SORENTO EX
Hard to say...sound like something may have gotten shorted out. You might see if it is jammed. On many vehicles (not sure about yours...you'll need to check your owner's manual) there is a manual override for moving the sunroof glass...near the sunroof, there should be a cap that you can take off and use an allen key wrench (or similar) to move the sunroof (sort of a 'hand crank' mechanism.)
If the sunroof is BCM controlled or monitored...it is a long shot, but you might try resetting the BCM computer...remove battery cable for a few seconds...
Kia Sorento, 2006, 2.5 ltr, CRDi XT, Diesel Auto
Hello,
On the mk1 Sorento, according to the handbook you need to do the following if your sunroof fails to open.
1. Remove the overhead light lens above the front seats.
2. Remove the two (2) screws, and then remove the overhead con-sole.
3. Insert the emergency handle (provided with the vehicle) and turn the handle clockwise to open or counterclockwise to close.
113470
This of course is alright if you have the handle. If you didn't get one with the car then see if you can contact a Kia main dealership and see if they can supply you with one. Alternatively, you could look on Ebay and any other auction sites to see if anyone is breaking a Sorento, and has found a handle they don't know what to do with.
Best of luck!
