Does anyone have a diagram of the proper locations for jacking up the 4G Sportage FWD?
I know there are the two locations per side on the rails behind the front wheel and in front of the rear wheel, but I'm wondering if there are locations, like some of my other vehicles have, where you can use a floor jack in the middle to raise both the front wheels or both the back wheels at the same time.
If the vehicle can be jacked up from a location other than the side rail spots, then jack stands can be put at those locations. If there are no other jacking points other than the side rails, where do you put the jack stands after jacking the vehicle up from the side rails?
