Hi all,
Just brought a 2001 auto sportage, gave it a good check over and all seems to be good, even the fuel tank is solid (ish:) read the forums to get some ideas!
I am about to do a service, sparks, leads, oil and coolent
But was wondering if there is anything else that i should carry as a spares to ensure reliability, im thinking along the lines of relays etc.
Which relays would be worth carrying and is there anything else i should be doing?
Spending monday undersealing and cleaning up the earths.
Many thanks
James.
Greetings,
You really shouldn't need to carry any extra relays (Main or Fuel Pump) unless you are intending to travel / use the Sporty in a remote area without access to any auto stores, etc..
*re: tune-up : also consider changing the fuel filter if original / unknown condition..
relay check: key on / engine off:
relay check: (2nd test) - key on / engine on:
after cleaning the earths, check voltage at the battery, pos. battery to motor ground, pos. cabin fuse box to frame ground, with both tests, all readings should be within .5-.7 volt of direct battery voltage..
If not, consider changing out the Main and Fuel Pump relays.
re: cleaning & sealing earths - I would also check & clean the fuel pump ground ring, located under the cargo carpet access flap (tilt rear seat forward) - poor grounding to the fuel pump can/will contribute to early fuel pump failure..
Regards,
GottaCruise
