Has any of the SX owners noticed that the exhaust is "loose". going over just small bumps and such will move the exhaust quite a bit. I was wondering if there was anything of other exhaust hangers that we could buy? Thanks again.
I bought one of those...sadly, I didn't where to secure it so I used a couple of wide Zip-ties instead. I wrapped two Zip-ties around the rubber exhaust hangers on each side.There is a lot of movement in the SX dual exhaust as it comes from the factory, very bad if you have a hitch. Not so much a problem otherwise. I secured mine with a couple universal exhaust hangers similar to this:
Walker Exhaust 36272 Hardware-Hanger-Universal | Exhaust Hangers
have someone drive your car and you drive behind it. if it still fine ill trade you lolMine is fine.............
I found pre-threaded bolt holes on the side of the frame, just had to find a bolt to fit and I think I had to drill out a hole on the hanger to make it slightly larger. Put one on both sides, the exhaust barely moves at all now.I bought one of those...sadly, I didn't where to secure it so I used a couple of wide Zip-ties instead. I wrapped two Zip-ties around the rubber exhaust hangers on each side.
Thanks for that! Driver or passenger side?I found pre-threaded bolt holes on the side of the frame, just had to find a bolt to fit and I think I had to drill out a hole on the hanger to make it slightly larger. Put one on both sides, the exhaust barely moves at all now.
