Engine is stopping and starting in about 2 seconds. Causing a violent action without throwing any codes...
2003 Sorento EX, 3.5 v6, automatic, with 160,000 miles. Very well maintained and running flawless up to this point, took a trip and that's when it all started.
It's not like a single cylinder miss, it is more all cylinders stop and then restart. (I'm going to refer to it as a miss) it missed, 5 seconds later missed again, 10 seconds later missed again. Slowed down and it didn't come back for another 500 miles of driving.
Then it happened again, and again. More frequent and longer duration.
I finally got a code for misfire cyl.6.
Replaced plugs, wires, and coil packs.
Same problem getting worse...
Finally get another code, camshaft position sensor.
Replaced camshaft position sensor, same problem getting worse.
It now does this in neutral at all rpm ranges. (Some days it doesn't do it at all).
I'm looking into ground locations now but any thoughts or help would be appreciated.
FYI fuel pump and injectors replaced at 100,000, with plugs, timing belts,thermostat, accessory belts, at that time just because 100k.
More info.
It's jumping in and out of open / closed loop at this event. I also just got another cam pos sensor code, but it tests out as good.
More info.
