1 - 7 of 7 Posts
hey guys is there anyway i can modify a 2001 rios engine to get more power with out purchasing anything if not then what can i purchase
Don't we all wish we could get more power out of these things. You COULD try a K&N drop in air filter but I really doubt you'll see anything noticeable from it and it'd probably be a total waste of money.
Bottom Line: These things are not built for power.
2004 Kia Rio
I put a K&N replacement in my '04. Noticed a bit more power and better mileage. Putting higher octane gas helps too. :57:
Make your own short ram intake! I used 2 1/2 inch pipe that I picked up from a local tuner shop. K&N makes a filter to fit this size pipe also and Nopi carries it in stock (around $30). Dont forget to make your mass air flow meter wires longer by unwraping them from the conduit they are in. The filter is small enough to fit in front of your battery behind your driver side headlight. If you got any more questions just drop a line I will be more than glad to walk you though the details of all kinds of Rio stuff. Later!
2002 Kia Rio
Just bought a 02 Rio and it has full cold air intake header full high flow exhaust slotted and cross drilled rotors strut tower bar and now i just have to figure out where the precious owner got the parts for the car
1 - 7 of 7 Posts
