Kia Sportage GT-edition CRDI 2.0 -16 // Volkswagen Passat 4-motion -17
Hi!
I have been having some wierd electrical problems with my CEED -08. My dashboard sometimes flashes like i was turning the "lighting knob" on the left side of the steering wheel (flashes bright orange and normal orange). It flashes 4-5 times and then stops. The driver seat belt light in the dashboard lights up for 2-3 seconds. It then returns to normal as if nothing happened. No fault codes no nothing...
I was also wondering this also has something to do with my stereo. The stereo does not shut down when i pull the key out of the ignition. I have to turn it of manually. I think it turns of by it self after a couple of minutes.
Anyone had similar issues?
Kind Regards
Jens
pro_ceed 1.6 CRDi 66kw (2008)
There were some users reporting the same issue.
Are you holding your cell phone in the area in front of the gear stick ? (below the ash tray and where the USB/AUX/cigarette lighter connectors are).
The cell phones were causing interference with the on board electronics when being placed there. When moved away, the problems were gone.
