Hey all. I hope someone here can give me some guidance. I have a 2000 Sportage 2wd Auto. I recently swapped in an engine out of a wrecked sporty. I had a few issues with some connectors being undone, it was late we were tired and we missed them. Now it runs great, lots of power, no check engine lights, its good. Except the AC doesnt work, the wiper fluid pump doesnt work and now my windows wont roll down. The windows were working after the swap but very slowly. Im guessing I either have a ground issue or another connector undone. Ive looked the best I can with it on ramps and I checked the ground from the body right below the battery to the intake and to the battery. I also checked the ground wire on the bellhousing by the starter, its tight and clean but until I get it on the lift I wasnt able to trace the other end. When we did the swap we dropped the tranny first to make it easier to get to the connectors on the back of the engine without breaking anything. We reinstalled in the reverse, engine then tranny.
I downloaded the service manual from 4x4wire and cant find the wiring diagrams in it. I also checked KiaTech and found some of the diagrams but they are kind of vague as to locations and Im not very familiar with how KiaTech is layed out. The items above that Im having issues with seem to share a ground G300. The problem is that I dont know where that particular ground is. Does anybody have any insight or any other ideas? Maybe a connector they share? I did check the fuse for the windows and it is good and there is power to it, but none at the window switch.
