I am having problems removing the brake drums form a 98 KIa Sportage EX 4X 4
Do you have to remove the 4 center botl n the hub before removal or not ?
:blink:
Yes, you must remove the 4 lug nuts as well as the 2 phillips screws. The phillips screws will require a #3 driver. A #2 won't remove them.
Once the 4 lugs and 2 screws are off the drum should pull off.
