1 - 11 of 11 Posts
16 Sedona SXL
I think there just are no DRLs for US spec Sedonas. Canadian spec Sedonas have DRL due to it required by their regulations, but I think they essentially put a bulb in the high beam position to use as DRLs.
Does the 19 EX have the headlight cluster with the LED strip like SX and SXL? That strip totally looks like it should act as a DRL, but it is not as bright as normal DRL LEDs and only comes on with the running lights. There's a thread here (above your thread) where a poster was able to hack them to be always on when the engine is running so they sort of act like dim DRLs. You essentially cut a wire in each headlight housing and connect the two wires to the fuse box for power.
2017 Sportage EX
It appears many people are confusing parking lights with DRLs. Per USA regulations, parking lights and DRLs have different minimum and maximum intensities. The maximum allowed intensity for parking lights is less that the minimum required intensity for DRLs, so parking lights are not DRLs per se. However, the same lights may be used for both functions by changing the intensity. That's what my 2017 Sportage does. The same LED clusters function as both parking lights and DRLs, but are much brighter as DRLs.
16 Sedona SXL
KIA calls them "positioning lights" instead of parking lights I guess. In any case, the earlier model years of the current Sedona has an LED strip that really should be DRLs but Kia decided to make them dim position lights instead. That's what I was referring to. There are no actual DRLs on the Sedona.
I've never seen the same LED bulb act with two intensities as both parking light and DRLs. So in your Sportage the same LED is on very bright during the day, acting as the DRL, and then when the parking or headlights turn on, they dim and act as the parking lights? Or are there multiple LEDs in the same cluster, with some really bright which act as DRLs and other separate LEDs which are dimmer and act as parking lights?
2017 Sportage EX
As best I can tell it's the same LEDs operating at different intensities.
Stateofdate check my post with photos:
My connector in lamp has 7 pins and my LED is not working. I found of bottom the lamp, green board with driver for led. I connect shortly 12V and this is working. I must change yellow position lamp (we have in Poland white position lamp, yellow only for blinker/turn) to LED as position lamp.
2016 Kia Sedona SXL 8-Pax, 2012 BMW 335i (F30), 2005 Lexus RX330
I hate it when people say parking lights when in reality no one really uses these light as "intended"...
When people park, who uses the lights?!?
As referred above by one of you, these should really be called position lights.
With that rant out of the way, Kia unfortunately didn't make DRL for the Sedona.
The lights you see are position lights.
But personally I use these position lights as DRL, so Everytime I drive, I drive with the position lights turned on, and don't tell me it is against the law...
Because That's a stupid law...
I agree that position lights cannot be used alone at night for driving, but other than that... Position should more than be fine to be used during the day while driving.
Sent from my Nokia 6.1 using Tapatalk
'16 Sedona SX, '09 Genesis
Let's be really honest... these are vanity lights, designed mostly for looks. Ever since BMW started with their "angel eyes", every mfr under the sun has had to put some kind of eye brows, slashes or winkers in their headlights... especially since the proliferation of LEDs. There are a few that are bright enough to work as Daylight Running Lights. Most, including the Sedona's, will get washed out on a bright sunny day.
In some locales (European countries?), where the Law requires cars to have "City Lights" when driving at night in brightly lit metro areas, these probably would suffice. Here in NA, they serve little to no purpose.
Personally, if I want DRL, I'd just turn on the low beam.
EXACTLY.
this truth needs to get out to the general population...
Along with the fact that people should not be driving with their high beams on when there are other drivers on the road !
1 - 11 of 11 Posts
