1 - 20 of 47 Posts
Considering that I have not found any DIY articles about the audio upgrade I decided to write my own.
Since I didn't have enough time today, this is part one, which includes changing the front speakers with new wires into the doors and isolation of front doors.
Tomorrow I will hopefully have time to finish the install of the power cable, the ground cable and the cables from the front doors to the boot.
Unfortunatly I didn't take any pictures of the RCA cables going to the headunit (I forgot). The guide to take out the headunit can be found here: rajce.net | place your pictures have to be...
I connected the RCA with the high-to-low adapter:
It's not the best thing to use, but pretty much the only one if you want to keep the original radio. I connected the remote wire to the radio on the connector A, pin number 3
Now, to the DIY audio upgrade part 1.
First you have to take off the front panels.
There are 4 screws and others are just plastic "poppers".
1 screw is located behind the lever for opening the doors (you can see the plastic cover over the screw).
1 screw is located behind the midle of the door, where you grab and pull the door to close (there is also a plastic cover over the screw)
2 screws are located at the end of the doors (to the back part of the car) under a plastic cap - you just pull of the cap and you will see the screws
Discussion Starter #2
When you have all the screws unscrewed, it's time for plastic "poppers". I found it the easiest to start at the bottom in the middle.
There are 10 "poppers" to pull out and it's rather easy (I got the doors off in less than 1 minute including the screws and without breaking any plastic "poppers")
Before you take off the panel, you have to remove the tweeter panel.
It's rather easy to remove, but start at the bottom - and pull it towards you and a bit up - on the picture you can see the way plastic falls into the holes.
Than just simple pull the door panel up and unhook all the connectors.
When the panel is off, the doors look like this
Marked things are:
- yellow --> where the poppers are
- blue --> the side screws
- red --> 10 screws that hold the inner plate (the silver)
- green --> plastic covers used for getting the window/glass out.
I decided to isolate the front doors with damping material.
First I opened the plastic covers (green on the above picture), reconected the door panel on the conectors and lowered the window down to about the midle position (half open/half closed).
Than trough the holes where the plastic covers were, I unscrew two screws and trough the hole to the front of the car I unhooked the window (rather simple but impossible to take a picture). Than you just pull the window upwards and out.
IT IS IMPORTANT THAT SOMEBODY HELPS YOU WITH THIS AS THE WINDOW MAY FALL INTO THE DOOR AND BREAK - SOMEBODY SHOULD HOLD THE WINDOW WHILE YOU ARE UNSCREWING THOSE 2 SCREWS AND UNHOOKING THE WINDOW.
cee'd CRDi LS Mercedes SLK350 Honda Fireblade
Are you keeping the original radio and replacing the rest of the stuff?
Before removing the inner silver plate you have to remove the speaker. Unhook it from the wire installation and than drill trough the marked areas.
It's a rather crappy blaupunkt speaker with no magnet (the irony is that I work for the main importer of Blaupunkt in my country )
Next thing was to remove 10 screws marked with red and to remove the silver plate. I had to unscrew 3 screws to the right of the picture, where the door locks (I forgot to pinpoint it on the picture). I was unable to get the plate out, but was able to pull it away from the doors enough to isolate the doors.
Isolation/damping material - buttyflex
Original doors
halfway done
Isolated/damped doors
After the isolation I put the inner silver plate into it's position and screwed back the 10 screws and installed the window back in - about 2 minutes of work. Not hard, but again, SOMEBODY MUST HELP WITH THE WINDOW.
Than it was time to put in the new speakers. I had to find the appropriate speaker holders/rings. Since there are non for the ceed/pro_ceed available at the moment (at least I couldn't find them) I had to find something that will fit the original holes on the doors.
The closest I came with speaker holders for the Alfa 147 by Phonocar.
'no magnet' ? how do they work without a magnet to bring the cone back?
Discussion Starter #7
From the top it looks like this
I than used a tool for making holes bigger (every step on the golden tool means 2mm bigger hole) and some plastic "holders" (you will see later what I mean)
I made the original holes bigger (they were about 4mm big originally and I made them 8mm big) and inserted the plastic "holders"
Discussion Starter #8
This plastic holders are used to screw in the speaker adapter
To make the install better I used a sponge-like self attaching thing and put it on the speaker holder, so there is no air leaking / space between the speaker holder and the door frame.
Discussion Starter #10
For the speaker upgrade I went with the MB Quart RVF 216 speaker system that I had in my basement.
Comparisment between the new and the old speakers.
Than it was time to get the new speaker wires into the doors. Considering that I will have 4x130w rms amplifier for the front system (2 channels for the front and 2 channels bridged for woofer) I couldn't use the original wires as they are too thin (I presume about 0,75mm2).
The wires I used are:
- 2x2,5mm2 from the amplifier to the crossover
- 2x2,5mm2 from the crossover to the midbass speaker
- 2x1,5mm2 from the crossover to the tweeter
First I tried to get the cable into the door trough the original cable canal. But considering that that would involve drilling trough the original connector I gave up on that option.
After looking at the doors I found 2 holes on the car - 1 on the outer part towards the doors and 1 inside (under the plastic).
To make the installation of the cables as easy as possible I removed the plastic under the drivers legs.
There are 4 screws:
Two from the side ( you have to remove the side plastic first)
And two under the steering wheel (unfortunatly no picutre - they are at the bottom of this plastic, you cannot miss them).
Unscrew them and than you have to pull the plastic at the top (there is the same metal popper on both sides of the steering wheel)
Discussion Starter #11
Than remove the plastics on the side of the car (only poppers). I found it the easiest way to start at the back, first to lift the outside part (where it's the metal "ceed" sign) and than when you get them all out just grab the inside part of it at one and and lift it up.
Than you unscrew the lever for opening the front bonnet (engine) bonnet. One screw in the middle of it and than you just pull it off.
When it's off, you have to remove the foot rest. Start at the top, pull it towards you so the "popper" let's go and than pull it up and it should get out.
Afterwards, remove the plastic where the lever for opening the engine bonnet was (just pull it off towards the opposite side of the car, rather simple).
Under it you will see a plastic/silicone cover. There is also a similar silicone cover on the outside of the car and I only have the picture of it on the outside.
I got the cable trough those holes (I made a hole in the silicone cover so the cable went trough and than put the cover back on its place)
Discussion Starter #12
Since I didn't want to drill trough the original cable connector I made a hole in the sillicone cover in the doors - the hole in the door is big enough to make the hole under the original cables and still get into the doors.
Unfortunatly not seen on the pictures is the hard plastic tunel for the cables that went from the first hole on the car frame trough the sillicone cover in the doors so the cables are protected better than in the original cable tunel (from the car to the doors). I'll make a picture tomorrow.
Inside the doors I came out with the cable as original cables.
On the picutre you can see where I decided to put my crossover. There is a lot of space there but still - meassure it before you install it.
When I finished the cables it looked like this.
Discussion Starter #13
The cables for the speakers were done like this.
Isolated.
All the wiring I've put in the doors have been straped to the original wires so no wire is loose. I also put the original audio connectors (for the tweeter and the midbass speaker) in the clothing material and straped it to original wires so that they won't bang against the doors and make noise.
After it the speakers went in, the tweeters went in and I've put the door panels back on - the same way as I've took them off just the other way around.
This is the end of part 1. I'd put it all in one long post but the forum is limited to 4 pictures per post. Maybe a moderator/admin can merge my posts into one.
Tomorrow I'll show you how and where to put 35mm2 power cable, how to get the cables (power, speaker, RCA) to the back, how to take the rear seats out and how to make good ground for the amplifier. Later on (when I'll have time) I'll make a fiberglass box in the trunk for the 10" subwoofer.
Thank you for listening, I'm opened to questions.
Simply fantastic, Crammond, congratulations. :clap::clap:
Discussion Starter #15
I made some pictures today that were missing yesterday.
Cables going from the car into the doors (protected).
door side
car side
Where the cable gets inside the car.
Position of all four of the screws for removal of the plastic under the steering wheel
This now completes part 1. I will now write part 2.
There are 4 screws:
Anybody knows how to dismantle this part on the passanger side?... :confused:
ceed HB 1.4 cassa white
@crammond: WOOW ..The best of... !! congratulations & thank's ! :57:
Kia Pro_Ceed 2.0 Sport
What size are the original OEM speakers? I have a set of Infinity Reference 6510cs 16.5/17cm components out of my old car, would they fit easy?
1 - 20 of 47 Posts
