hey guys, i was leaking alot of oil from under my distributor, so i changed the o ring inside it, and cleaned everything up, upon installing, one of the bolts sheared off, lucky i got it out, i replaced it with a bolt with same size threads, a few days later i look and see oil dripping down the radiator hose, come to see the leak is a little worse, i oiled the new o ring before i put it on, i torqued the disty to spec, what are my options? this oil leak is driving me crazy<_< could i use rtv around the outer part where theres no gasket? or is there a reason that there isnt sealant there, thanks for any input guys, thanks -matt.
