1 - 8 of 8 Posts
Sorento 2005 EX
Hello all,
I am trying to buy oil for a Kia sorrent EX 2005 differential oil. My understanding is that 2005 do not need lsd correct?
I can not buy and different oil none LSD in autozone napa or etc
all I can find is 85-90wt. Do i just buy that and add the lsd?
I have read that the rear requires is and then i have read it is not required. I am confused
If you have a 4WD you need the LSD gear oil. That is what I was told. Be sure to raise the rear the extra 8 inches so you get all the fluid in there.
As far as I am aware, 4WD Sorentos with traction control do not have LSD. All other 4WD models do. If yor not sure just use LSD oil, it won't harm a conventional diff.
Sorento 2005 EX
So then what would be the correct oil for my sorrento EX?
I dont believe I have 4x4 if I do or dont how can i tell the difference?
The only thing i know is that i have a nob for snow.
03'VW Passat - mine | 03'Sorento EX 4X4 - hers
I've been using Valvoline 80W-90 Durablend synthetic gear oil (bought in Autozone) for the past 40K-50K in rear and front differentials and no problem. it's actually says on the bottle that it's for LSD. But you can always get for non-LSD and just add LSD additive, should be in Autozone too.
1 - 8 of 8 Posts
