2009 Borrego
I need to replace the cv boot on my front driveshaft. Do I really need to buy an axle assembly just to get a boot?
I am not having any issues with the axle, the hole was discovered during an engine swap. So I really just would like to be able to replace the boot and not spend $700+
Suggestions? Ideas? DIY would be fabulous
Subaru WRX
is it a boot for a front cv axle or for the prop shaft going from transfer case to front differential? i know you can get boots for the cv axles seperate, but im unsure about the prop shaft. i would have to check with parts dept.
