kia cd5 1997
my car is kia cd5. i cannot open the car door from inside (driver side). but from the outside it will open. What will i do?
Greetings,
If your vehicle is a Kia Ceed, recommend going to the ceed forum:
Kia Cee'd Forum - Kia Forum
and searching / posting your question there,
From what you describe, it sounds like the rod that connects the inner door handle to the lock mechanism inside the door is disconnected: it would require removing the inner door panel -> and pulling back the plastic shield to look inside the door to see what exactly is the issue.
If any doubt, call around locally to a mechanic garage or better, an auto body shop, to see what they would charge to open the panel up / and fix.
Hope this helps,
Regards,
GottaCruise
