G
I have been having a problem for months with alternators. It has been repalced 4 times , including new belts. It continues to either eat the belts (last one was in a week and broke), squeak constantly and burns out the alternators. The battery and water pump have also been replaced. I haven't even had it 5 years yet. Has anyone had a similar problem or know what is causing this?
ok, for the alternator, there is a long brass screw above it, ti takes either an 11 ot 12MM socket, use a torque wrench and loosen up that belt a bit until there is a little bit of slack. That is if its too tight, and if its too lose then sighten it uptint here is no mroe squeak. Hope that helps.
