2008 Rio LX, 2007 Honda Shadow (Bike)
2005 spectra check engine light is on. replaced cps and reset computer and light came back on after 5 miles,same code advanced timing. Any idea what to do next. Thanks
This points to a mechanical problem. Does the car run normally? Could be the variable valve timing solenoid. There's more info at the link below. When was the last time you changed the timing belt? I had a car that skipped a tooth on the camshaft sprocket and set a similar code.
Code P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
