Had the same issue. Changed the belt. Squeal gone. Noticed that the tensioners for all belts are locked inn place by tightening the pulley on the actual tensioner. My pulleys were loose and the tensioner would loosen up over time.
the belt is not tight, only just loosen the slide bolts and put a big bar down the back of the compressor to adjust or put Russian Tallow on the V side of the belt
