Hey Axeman I got the code its P0442 the mechanic said its a EUAP small leak detect so he earased the code wich turned off the check engine light he said if i put gas in my jeep while its started that could have caused the light to go on because it take between 1 and 3 pounds of pressure in my tank or the gas cap but it looks fine what do you think about all this
P0440 or P0442 trouble codes can usually be traced to a leaking fuel cap. If the cap does not have an airtight seal it can result in these nusiance check engine lights.
Get a new fuel cap. It should fix it. And make sure the cap is completely sealed when refueling. One or two "clicks".
