Hey Axeman since you seem to be the man to ask my check engine light comes on every once and a while I hade a LOCAL GARAGE CHECK and his cumputer dones work on2001 only on 2000 and older and the dealer is one hour drive does it matter or can it harm something if I kept doing like I have since it was new by unplgging the battery for 20 minutes it turn off the light for a while my jeep run perfect with light on or off give me your oppinion thanks
Tell your local guy that the 2001 is identical to the 2000. So if he has data for 2000 it applies to the 2001.
You should have the ECM scanned to find out why the check engine light keeps coming on. It's probably not serious but it should be checked. If your local guy doesn't feel confident that he can work on your Sportage then just have him scan the ECM and readout the trouble codes. The code, or codes if more than one, will be formatted PXXXX, where XXXX will be a series of numbers. Get those numbers and post here and we can provide a fix.
