Hi every one, I own a 99 Kia Sportage my Check Engine Light went on, so I took it to the work shop and they told me it was a problem with the purge control valve, I asked for the code and they said it was:
code 0440
open ciruit in the purge control valve
They changed the valve but but the Check Engine Light does not go off, Can you help me please :( , what can i do, any help will be apritiated
Yes, can help. Trouble code P0440 is almost always caused by a defective fuel cap. If the cap does not seal properly or is loose the engine computer will set that code. Replace the fuel cap with a new one and make sure it is tight. That should fix the problem.
