Hi guys,
I love my 97 Sportage 4x4, but she is quite fond of the check engine light- It goes on a LOT!
Everything from needing a new gas cap to 02 sensors going out- The local show charges me $100 to check it and the local Autozone doesn't have a scanner to check the light for me.
I found a couple of code readers on-line and was wondering what you guys thought- here they are- Thanks a million!!
Jennai
http://www.etoolcart.com/index.asp?PageAct...ROD&ProdID=7207
http://www.etoolcart.com/index.asp?PageAct...ROD&ProdID=4168
Check this one out (you can get it at Autozone):
I have a slightly older model, works great.
http://actron.com/product_detail.php?pid=16151
MSRP $179.99 USD
OBD II AutoScanner CP9135 can easily retrieve diagnostic trouble codes (DTCs) and code definitions from your vehicle's computer, leading you to the problem area. Use on all 1996 and newer OBD II compliant vehicles: North American, Asian & European.
* Reads and erases Diagnostic Trouble Codes (DTCs) and turns off check engine light
* Retrieves all Generic OBD II trouble codes (P0), their definitions and pending codes
* Enables user to quickly and easily link to their vehicle
* Large easy-to-read LCD screen provides the Diagnostic Trouble Codes and their descriptions
* Extremely user friendly menu provides:
o Monitor Status and I/M Readiness to determine if vehicle is ready for an emissions test. I/M Readiness is an excellent function to use prior to having a vehicle inspected for compliance to a state emissions program
o All emission testing facilities will fail a vehicle which has the "check engine light" lit at the time of the test
o Alerts user to any pending Diagnostic Trouble Codes (DTCs), and reads Malfunction Indicator Lamp (MIL) status
o Menu-driven interface combined with "hot keys" for Read and Erase functions for quick and easy use
* Includes CD software that contains an additional 3,000+ Diagnostic Trouble Codes (DTCs) and their descriptions
* Tool is updateable, accommodating future vehicles
* Attached OBD II 16-pin connector cable provides both data and power connections
* 1 year warranty
* 8 ft. cable, rugged housing, oil and grease resistant
* Assembled in the USA
