2007 Kia Rio5 SX
This light has either been blinking or is staying on (solid). Is this a basic fix? The engine is fine on the highway yet shifting gears (manual trans) is often intermittent.
2014 Kia Rio
Have you had the codes checked? No way to tell what is happening without that. Generally codes are set when there are emissions issues so a transmission issue probably will not show up.
2007 Kia Rio5 SX
Yes, the light has been intermittent on/off. Today the code read P0301 misfire in number 1.
Miles and maintenance performed? Your original owner?
Could be due for spark plugs, or perhaps a coil or fuel injector issue......
2007 Kia Rio5 SX
MX is current and documented from Day 1. 278K on the mileage. I did try and check out the condition of the spark plugs once about a thousand miles ago and was unable to retrieve it from the number one cylinder. I plan to re-visit this.
Thanks a lot
