Hi my 06 carnival check engine light come on. I had a ultra tune check out and reset it and they say the left bank is running lean. the first time this happened i got the fuel filter changed and the fuel pump. the second time it happened they check it out and it was the same code and the check the oxgen senser and that was working fine so they reset the code. And now the check engine has come back on.:(
Has anyone had the same problem and has solved it?
cheer mal vane
Discussion Starter · #2 ·
HI i have solved the problem. I replaced the fuel cap. Because the fuel cap wasn't sealing properly which made to pressure in the tank wrong. I am so glad i didn't have to replace the other o2 senser
Thank you for posting what you found as this can help others...
If you can post in the future the OBDII codes you may get better results...
Also please fill out your CP with some general info so that others know what area you live in (I know Australia as I'm a moderator here).
Also things like engine (V6/I4/gas/diesel), tranny auto/manual, mileage, and things tried also helps us to help you...
I hope you will enjoy our small "global" forums and will come back to visit us...
