1 - 10 of 10 Posts
My 98 sephia all of a sudden started missing. Around 1 minute later the check eng light came on. Before the light came on I though it was the plugs (because they have not been changed in 50k miles). Would they make the light come on though?
Thanks
The CEL usually means something emission related is not working properly. It might very well be a misfire. The only way to know is to read the codes and check online and see what the codes are trying to tell you. Autozone reads the codes for free.
Thanks for the reply. I found a place close by that will let me use their diagnostic tool for free, but I have to do it myself. Is this easy to do? How do I do it?
Thanks again.
let me guess the cel is blinking. replace plu wires
The hook-up for OBD II is under the steering column. Just attach it there and the reader should prompt you on what to do. Simple procedure. Just make sure you write the codes down before you clear them, otherwise you forget it and its no good. If you google obd ii you will find websites that will tell you how to read the codes and what each code means.
Dear Forum Dwellers:
I had exactly this problem with my 01 today. Reviewed this thread and others with similar problems.
Took the advice that says go to advance auto and get the codes read.
In my case, the codes called for replacing the plugs and plug wires, which I did, (not the coils) and that baby purrs like a kitten.
Moral of the story: Thanks, forum dwellers, for this resource of information! You saved me some dollars in repairs,
This calls for a dancing banana:
:banana:
if you get a misfire code it is 99 percent of the time the plug wires.
Question (sorry if this is a double post):
How do you shut the CEL light off?
Will it shut itself off?
I thought I read somewhere on here you unhook the battery cable.
2002 Kia Magentis
You have to have the code read and cleared by an ODB II scanner. I would think you want to know why its on though.
I dont think there is a "backyard mechanic" way to clear the light like the ole days.
You dont need to have an obd2 reader to reset the code.... just unhook neg terminal on the battery and release all the stored memory/power by hitting the brakes after unhooking the cable. if you have an actual problem though it will come back on....
this is the "backyard way" to clear the codes...
in some cases the cel would come on then shut itself off... like maybe in a lean or rich condition that the ecu "repaires" the condition. the ecus on obd2 are adaptive to a certain extent...
Like when you install a cai it will adjust the fuel trim to meet the colder air...
1 - 10 of 10 Posts
