1 - 11 of 11 Posts
2012 Sportage EX
I used to be able to do this in my 2000 Ford Taurus. Now after 10 seconds or so the power at the 12v port is cut off. Is there a way to keep this port HOT at all times like a cigarette lighter? How many times I've been screwed with a failing cell battery and no way to charge it and I'll be damned to run my car wasting gasoline just to charge my phone.
Cerato S Hatch Auto
Some cig. lighter sockets don't stay hot either. I guess you could change the wiring of the 12V port (what sort of connector is it?), or use a cig. lighter type charger for your phone.
I keep a cig. lighter adapter for my Nokia and charge it while I'm driving, but in an emergency, I wouldn't mind burning a little petrol. BTW, if you are using BlueTooth, that will suck the power out of your mobile much faster than you might imagine, even if you aren't using the phone much.
Many SUVs and crossovers have 'always hot' 12V receptacles - just not the Sportage. Maybe this is something they will do with the next model. It's great to be able to leave the phone in the car charging while you're doing something else. My 2003 Saturn VUE even had that. I was kind of shocked the 2011 Sportage didn't have it.
2012 Sportage EX
Exactly! Once you're used to a car having this ability and then to buy a new car that doesn't havre it, it really sucks! I always would have my phone charging if I ran into the store or gas station or during my lunch break.
You'd think with the Sportage having 2 12v receptacles, they could make one HOT and the other just with the ignition on.
Is there a quick and SAFE way to make one or both of the receptacles hot?
Just running a red wire to the battery + lead?
sportage base model manual trans
three
mine came with three .
Old cars have these "hot" lighter plugs -- they're wired to the battery. Modern cars don't directly, so that the entire car (ideally) turns off completely, leaving only time to kill the battery.
It sucks if you want to charge your cell phone, but it's nice when the car can turn itself on later.
njerald is completely right. Just wire one in under your dash or something. An audio shop, or maybe even the dealer, will do this for a small charge.
2012 Kia Sportage EX
I went through the fuse box to test for hot and not. 12v cig ports are not. Honestly though, with only 660 CCA (cold crank amps) on the battery it could slow drain your battery if you do charge your phone with the car off. I have 800CCA on my car and still wouldn't mess with it, especially if your alternator is providing less than 100amps to recharge your car. Buy a portable charger (much cheaper than a new car battery if something goes awry)
1 - 11 of 11 Posts
