Picanto 2011
Hi,
This week the car started having issues with the central locking, both via key and the door switches. The car only unlocks centrally but will not lock via the key fob or door switches. If I push the lock button on the fob all I hear is a light beep from the fuse box area under the steering side no relay noise at all. Same from the door switch. Unlocking works normally from both.
I tried the spare also, I can't see any obvious issues. It isn't the fuse since that controls both locking and unlocking. No loose wires I can see. All locks work individually.
I have a strong suspicion that it is the lock relay.
Any advice?
Thank you
UK, kia picanto, 2012, ecodynamics 1.2
Me too same make model and year, any resolution yet? I found, whilst trying to look for loose wires etc, that the door is open and you attempt to lock it (with key or door button) there is a louder clunking sound as if there is an attempt to lock it which doesn't happen if all doors are shut. Started to make me think it might actually be a programming issue so going to disconnect the battery today. Any help appreciated.
I have exactly the same problem. 1.25 2011. Does know one know what's wrong?
eg.
USA
UPDATE: Vehicle Information
Forum Rules
We have had two picanto 11 plates in the last month with the same fault and in the end because there could be so many reasons why it doesn't work we decided to bypass the cars wiring loom.and fit aftermarket remote kits this can be done for £200 and we need for two days we are based in bolton in Lancashire
AAA AUTOELECTRICS
07792217892
