2017 Sorento LX, Push to start.
I have a problem with the central lock. The buttons on driver and passenger door handles do not close of open the doors. The buttons on the driver door does not work either.
FOB proximity works well; When I press FOB, all the lights flash as if the central lock is working fine. After I lock all 4 doors manually, I press the lock button on the key fob, the car "locks" with the honk sound, piip!
There is no check engine light or any other indicator lights.
The key fob works perfectly to start car as well.
I got the Smart Key Antenna ASSY that's in the rear bumper (picture attached), plugged it in but still central lock does not work. I hate to use the key to open the driver door, then manually open the other doors from inside.
Anyone with an idea what could be the issue? Thank you
