My CEL came on the other day on my 1997 Kia Sportage base model 5-speed so i had the code read it is
P1309
Misfire Monitor AICE Chip Fault
Can any one help me with this problem i think it has something to do with the camshaft timing sensor but i could be wrong.
DTC P1309 - Chassis Acceleration Sensor Signal Malfunction.
The chassis acceleration sensor is bolted to the frame on the right side of the engine compartment. Passenger side if left hand drive. Just to the right of the strut tower and in front of the fuel filter. Check the electrical connector to the sensor. Make sure it's tight and no corrosion. If the wiring is OK the sensor might be bad.
If you want the diagnostic procedures send me an e-mail at [email protected].
Are you sure you located the correct sensor? According to my 1998 - 2000 FSM the chassis acceleration wiring is as follows:
Pin 1 - yellow wire with green stripe
Pin 2 - green wire with yellow stripe
Pin 3 - blue wire with green stripe
It's possible there was a change from 1997 to 1998. I'll send you the data that I have.
