I have a 2006 Kia Rio base model. Has approximately 140k miles on it.
Before you point me to the other threads on these issues, I have already read them and they no longer pertain to me at this point.
So I have had a p0446 code for quite a while and for reasons that need not be explained, I ignored it. Like most, I started having problems starting the vehicle and keeping it running after fueling up and it progressively got worse. Over the last two weeks or so, it would take about 15 minutes of trying to get the damn thing to start, so I decided to look into the problem myself. I found that the CCV is typically what causes this so I found one and replaced it today. I hooked all the hoses and wiring harness up and started the vehicle. I noticed that it was idling rough, but figured maybe driving it a bit would help. While driving it seemed real sluggish and after about a mile died when I started to come to a stop. I got it started and returned home where it died again. I have a bluetooth OBD II reader, so I plugged it in and found that I now had a p0449 code which is the code for CCV stuck open. I crawled under the car to find that apparently the wiring harness hadnt actually snapped in right and was dangling.
Now I cant get the car started at all. I tried kiatechinfo.com and found some troubleshooting steps and cant seem to meet any of the specifications across any of the terminals. I barely get anything when testing terminal one, and terminal two is not close to the 3.5 V that it is supposed to be. I also tested the resistance, and it was within specifications for a second, then jumped up to about 35 ohms....
Anyone have any ideas of what to do??? Right now as a last ditch effort I am trying to reset my pcm and hope that helps, but otherwise I am thinking that now I have a bad wiring harness that I will have to replace. Or possibly a relay issue???
