You need to remove the console that sits around the handbrake and Gearstick, there is a screw at the back of the console that you need to remove and also one at the front of the console, under a plastic cover that you need to remove first, I think there are a couple of screws in the little coin bins/key bins, then lift the console up, and you will see the adjusting nut on the end of the wire on the handbrake, can't remeber if there was one or two adjustment nuts, think there were two.
