I have a Kia Carens 2.0 crdi 2011, it has 170 000 km, recently it has hard start with long cranking, Cranks normally till battery dies sometimes but very hard to Start, even with quick start spray, once started the car runs like there were no problem at all, on the scan tool I have one fault: "crankshaft position sensor performance range/circuit", I decided to check the sensor circuit (three ends on the connector: ground, reference, signal), while inspecting the circuit the reference wire showed only around 2.5V, I know that the standard for sensors is 5V or 12V, the wires of the reference have no short and the problem should be with the ECU.
I want to simulate 5 or 12V voltage to the reference and see if the problem disappear to confirm its the faulty ECU, but I don't know what is the voltage the reference wire on this car.
So my questions are:
1. can any one tell me the voltage or have a diagram to this car where I can find it please.
2. If it is confirmed faulty ECU, can it be repaired since it is only one wire voltage altered, or should it be replaced?
Thanks to all
Thanks to all
