1 - 8 of 8 Posts
01 kia rio 95 rangerstang (4brl stroker 347 5 speed project ) 85 virago
Have an 01 rio start car if I push gas will rev and die if I don't just dies new coil wires plugs valve cover gasket if I spray start fluid into throttle body will idle till gone then die possible fuel regulator?
Discussion Starter · #2 ·
Tested fuel pressure have zero psi when I crank car could this be a weak pump or is it a fuel regulator if regulator where is it located? Help plz
Ok do you hear the pump run when you turn the key to the run position, It should run for a few second's. If not maybe an electrical issue. If it does and you have no pressure probably a bad pump or regulator. I'm pretty sure it is in the tank and part of the pump assembly. Also don't overlook a blocked fuel filter. http://www.kiatechinfo.com/ for service info. good luck, Reguard's Ronjohn
My pressure gage was faulty new gage retest 51 psi off the rail so not the pump did compression test 150lbs across the board car still starts and stalls this sucks :/
Could this be a timing issue or would I not get compression if so?
Figured it out no ground I feel dumb XD
Which ground was not connected or missing? Please tell to help the next guy that has a similar issue here. Glad you found it. Rerguard's Ronjohn
Discussion Starter · #8 ·
was the ground that bolts to the transmission was dirty cleaned ground and tightened bolt started right up
1 - 8 of 8 Posts
