1 - 12 of 12 Posts
'13 Rio5 LX Manual, '15 ZX14R, Honda VFR800, Ducati 748, '87 Buick Grand National, '13 Subaru BRZ
I'm at 30K miles and my rear brake pads are starting to squeel as I drive, so time to replace them. I'd also like to replace the front pads now so I don't have to deal with it in the snow this winter... better to just do it now.
My car is just a commuter, but I do drive fast. Should I stick with OEM pads, cheap aftermarket Autozone pads, performance pads...? not sure what I need. Any suggestions?
Kia pads and very good. They will cost you $75.00 for a set, front, or rear. If you buy autozone pads make sure you buy the GOLD ones. Don't buy the cheapest pads. I would look at your brakes with the wheels off before buying anything, just might need a good cleaning.
I just did the rear brakes on my 2011 Sportage at 38k miles. Next are the fronts, once I recover,,,lol. I used Auto Zone's Best Gold!
I've had experience with these on my old Tucson, and they stop, & last, better then the stock ceramics.
I tried NAPA's Best, first, expensive, and a spongy pedal, with slower stopping. :mad:
I think the AutoZones have brass stock in the ceramic mix to help them grip better.
Check out my post in the Sportage forum.
Good Luck, Mike D.
2013 Rio 5 EX, 1967 Chevy C10
*Shameless plug* If you're lucky and you have a NAPA near you, ask if they carry or will order you parts from their Altrom line. The store I work at stocks Altrom and it's NAPA's import line. The vast majority of the Altrom parts are OEM manufacturer and even use the same part numbers. The only problems I have found is there's not a lot listed just yet for the Rio, either because it's in it's second new model year or that Kia's not sharing information just yet.
We just got a buyers guide for Akebono, the rear pads have been out awhile, the front pads are new and coming out soon.
2005 Kia Rio
It seems to me that the rear pads wear twice as fast as the fronts, on these new Rios.
I work for a rental car company and out of the 12x Rio hatchbacks in the fleet, I have so far replaced only the rears. The kilometer are about the same and the fronts are 50% more life compared to the rears.
IMHO
2012 RIO SLS Signal Red
IMHO
:p I have done 58,000 kms and I am still on my original brake pads..you guys must be on your brakes all the time..
Discussion Starter #8
Actually, I drive my rio very fast, so when I have to put the brakes on - I put them on HARD. I'm tough on my little car, but no problems yet. Synthetic oil, K&N filter, and foot to the floor...
2013 Rio
Parking Brake Ajustment
I have read about rear brake pad wear. I wonder if the cause is that the parking brake is adjusted too tight. I checked mine and the handle goes to only 3 clicks not the 6-8 as speced. But I can't figure out how to get to the adjustment. Does the center counsel cover need to be removed?
Any help appreciated.
My car is a 2013 Rio EX 4 door, AT.
2005 Kia Rio
As Spec'ed
Could you please tell me where you obtained this spec;
been looking for specs for a while now (two days and not much effort on my part), could ya help me?
2013 Rio
It is in the owners manual under maintenance page 7-32 in my book. I did a test and found that with 3 clicks the parking brake will not hold the car on a slight incline. If I pull hard I get 4 clicks and that holds the car.So, is 6-8 clicks the proper adjustment? I'll check with the dealer in a few days.
1 - 12 of 12 Posts
