I have a 1999 sportage. The brake light on the dask turns on & off during braking.
I looked around the car. there is no brake fluids leaking.
Looking at the front wheels there are 2 hoses to the front wheels.
One is the hydrolic line.
What is the other one?
Looks like a vaccum line??
Because both are broke & handing off the metal pipes.
Could this cause my light problem??
Kia Carens CRDI Mk 3
Hi there the two pipes you have on the front 1 is
the brake pipe and the other is a vacuum pipe
for the front hub locks it
hope this helps
Thanks for the help
I replaced both hoses but the light still flashed on hard braking.
Looking closer at the master cylinder i noticed there are two wires coming from the plastic hydrolic fluid holder.
I took the cap off to find a float inside.
This float must activate the brake light.
The fluid was low. During hard braking, the fluid must have slid to the front & set off the light on the dash.
After filling it up & testing, the light no longer flashed.
Interesting, another example of a warning light with no problem to the machanical parts or operation?
